Hello The television set has 4 keys which are located on the front or the top of the set depending The VOLUME - + (- Vol +) keys are used to adjust sound levels.The PROGRAM - + (- P +) keys are used to select the required programmes. To access the menus, simultaneously hold down the VOL- and VOL+ keys.The PROGRAM - + keys may then be used to select an adjustment and the - VOL+ keys to make that adjustment. To exit from the menus, hold down the 2 VOL- and VOL+ keys. Note: when the Child Lock function is activated,
To change its picture aspect ratio, you have to go to its menu. As you haven't its remote control there is an option for that, mentioned in its user manual. I hereby send it to you. Do the same and access the aspect ratio.
on the model.
these keys are unavailable
OK.
My philips28 i can;t use AV is not woking and when tv is woking for about 2hours he will write swishoff plz help me
