Samsung M8800 Pixon - Unlocked QuadBand Cell Phone - 8MP Camera, GPS, 3.2" Touchscreen - Interna Logo
Posted on Dec 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Samsung Pixon screen freezes quite often & just doesnt respond. After a few minutes it work again. This happens frequently. This seem to be a common problem with this model. Can someone give a solution for this?
Anonymous
Level 3:
  • Master 409 Answers
  • Posted on Dec 21, 2010
Anonymous
Master
Level 3:
Answers
409
Questions
0
Helped
67495
Points
1209
The problem is a faulty contact from the touchscreen leading to the phone board. To be short: on the right side of the phone were the volume buttons are, under the touchscreen is the screen's contact. Try "detaching the screens face a little from the phone body exactly at the volume down button(using ur fingernail or something) and see if the touchscreen is responding in anyway. IF this is your case too...I suggest get a screw-driver and open the chassis, and trying to make the connection permanent, somehow.PS: you can send it back to warranty of a repair phone shop, only to force you to buy a new touchscreen and pay for the repairs, on a 99% working phone, with a faulty contact. The choice is yours:)
Good luck
My screen has locked on the samsung m8800 I have switched off and waited 5 mins, removed the battery and replaced it and nothing is happening, I cant even enter my pin
If the screen has frozen, there is one solution I found on the internet...
just follow this link
http://www.handcellphone.com/mobile/forum/screen-freeze
mine is working now
1helpful
My calibration on my samsung M8800 has broken i cannot touch what i want and i try to fix on the calibration settings but that does not work either what do i do ?
It is a problem in this set... after some time, your screen will stop responding at all... there is one solution I found on the internet...
mine is working now
But try it at your own risk
Samsung Pixon
It is a hardware problem in this set... after some time, your screen will stop responding at all... there is one solution I found on the internet...
mine is working now
1helpful
2answers
Touch of the cell is not working
Switch off the mobile and then recharge it full in off mode. If the problem exist, better take to a dealer
1helpful
Samsung pixon screen is not repsonding to touch
It is a hardware problem in this set... there is one solution I found on the internet...
mine is working now
Refrigerator quit working, now seems to be working
I am not an expert, but seems like when you emptied it out you may have defrosted the system in the time you had it off. What causes it to freeze up may have been the defrost timer not working properly. If the defrost timer is bad after a while it will freeze up again and stop working. Hope this helped
22helpful
Samsung Pixon touch screen frozen
The issue of touc screen freezing in he M880 is mostly due to fault in the contact. The screen contact is just below the volumen control buttons on the right. I inserted a fingre nain where the volume control is and pulled up the screena wee bit. near the volume up botton, I then inserted the tip of a tooth pick. It worked and the touch sensitivity is just as new :)
PS3 freezes but sound still works
when it happens, give it some time, like 5-10 min. the ps3 is most likely accessing the hard drive, and if it is, shutting down in the middle of it could currupt your hdd. if it doesnt work, even after 10 min, call sony tech support, but if it works fine afterwords, i dont see why it would be neccessary. unless it gets worse, i think you should just turn it on, turn it off after a few min, then back on, and then play.
1helpful
3answers
Touch screen wont work
Have you tried removing the battery and waiting for a minute and replacing it in the phone.
The phone will reboot and possibly your screen will work again.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
