Apple iPad 32 GB WiFi Tablet PC Logo
Posted on Dec 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need ipad - Apple iPad 32 GB WiFi Tablet PC
Anonymous
Level 2:
Scholar:
  • Expert 59 Answers
  • Posted on Mar 06, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
59
Questions
0
Helped
36229
Points
120
You need an iPad? I can't provide one, but there are many ways of getting hold of one.
if you just want to try one out, go to an Apple Store and have a play around. You can also buy one from there.
Secondhand iPads are available on Amazon and Ebay, for significantly less than it costs new from Apple.
Or, you could wait until the next iPad model is released (In a few weeks time) - then older iPads will be available at significant discounts.
Hope that helped!
Cannot open ipad asking for a pass code and says ipad has not been updated
You can try the default password or just remove the password. Follow below steps to do that.
Generally, the default passcode can be 1234 or 123456, and the digits rely on the blank number.
If this won't work, try below method.
When you find "iPad asking for passcode I never set", it is sensible for you to remove iPad passcode by restoring iPad with iTunes. The precondition is that you have backed up your iPad to iTunes before you forgot the passcode. Now let's begin to see how to get this work done.
1. Run the latest version of iTunes on your computer and then make sure that you do not connect your iPad with your computer.
2. For iPad with Face ID, you need to press and hold the top button or the volume button till you see the slider of power off shows up on the screen. Drag the slider from left to right to turn off your iPad. After that, plug your iPad into computer while holding the top button. You need to hold it until the recovery-mode screen appears.
For iPad with home button, you need to press and hold the slide or top button till you see the power off slider interface. Drag the slider from left to right to turn off your iPad. Afterwards, you need to insert your iPad into computer with proper USB cable while holding the home button. You need to hold the button until the recovery-mode screen displays.
3. In the interface of iTunes, you will see a dialogue for you to restore or update, you need to choose the option of "Restore" in the panel. Thus, iTunes will download program for your iPad. You need to wait for over 15 minutes until your iPad exit the recovery mode. Thus, you need to repeat steps 2-4.
4. Wait for the end of the procedure to set up and use your iPad without a passcode.
The process to remove iPad passcode via restoring iPad with iTunes is not so hard for you at all. You can give it a go to help you to pass through the passcode inquiry simply.
For more details, check: Fixed: iPad Asking for Passcode I Never Set
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
1helpful
4answers
Transfer photos from my PC to my ipad mini. I have tried iTunes but I don't understand it
Try downloading an app called Shareit.
When attached to the same WiFi, you can transfer Photos directly from iPad to iPad and even between Windows and Andriod devices. You start Shareit on both devices and send from one and receive on the other.
4answers
How do I transfer pictures from iPad 1 to iPad 2 .
Can you install Dropbox app on both tablets to transfer pictures? Or feel free to try this iPad file transfer program on your computer. Transfer Files among iOS Devices iTunes and PCs with Ease
Why doesn't the touch work on my ipad
The iPad's touch screen should always work, unless it froze. Try and restart the iPad (hold down the button on the top edge, close to the camera lens until the iPad turns itself off, normally a few seconds). If it doesn't work after a restart, you may need to reinstall the system, which you can do from iTunes (attach the iPad to your computer, open iTunes and choose 'Restore iPad' - you need internet connection to download new system). Have iTunes back up your iPad before restoring it, if possible, or data will be lost.
If none of this is possible, you may need a repair at a service centre. Good luck! :)
At the start , forgot 4 digit pass word,for ipadmini
There are several solutions to solve your problems. First you can try the default passcode 1234. But if you surely forgot 4 digit password, you have to restore the password. And below steps can help you.
For more methods, check: Remove iPad Passcode through Restoring iPad with iTunes
2answers
Disabled ipad 3
What wrong with your iPad 3? Maybe you can reply on the tablet replacement repair parts for iPad 3 to make your iPad return back new and health. Nowdays, there are more repair parts for fixing the unflexible and scracked.
3answers
How to play 1080p mkv videos on the new iPad
Well, the new iPad only supports to playback videos in MP4, MOV, M4V format. So, if want to watch 1080p MKV videos on the new iPad in 1080p, you need to convert the 1080p MKV to 1080p MP4 format first. From Google search comes this following guide shows you how to convert 1080p MKV video to 1080p MP4 for the new iPad.
Read this "Turn 1080p MKV to 1080p MP4 for The New iPad"
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
