Question about Panasonic Lumix DMC-FZ7 Digital Camera
DMC-FZ7 problems 1.When I bring the distance in closely --out of focus. 2. The closeup does not work....
Have you tried switching the mode dial to a flower icon?
The mode with the flower icon is the macro mode, you can shoot up to 5 cm from the subject.
Also, if you are very close to the subject, then the auto-focus may not function properly if the targeting area is not centered on the subject.
When I shoot macro with my FZ7K, I use manual focus, the auto-focus generally has trouble focusing up close.
I would suggest trying manual focus.
Posted on Jul 12, 2008
6ya staff
SOURCE:
Is there a long lens for the Panasonic DMC-F27?
Camera is currently equipped with a Leica 12X zoom lens. I would like to be able to take pcs. from a greater distance than this lens permits. Can you recommend a lens that I can attache to the Panasonic DMC-F27 that will enable me to do so? Thank you!!
Apr 14, 2013 | Panasonic Lumix DMC-FZ7 Digital Camera
I have a Panasonic Lumix DMC-FZ7. The problem is it doesn't read the memory card anymore. It keeps saying, "Memory card error. Please check the card." is there a quick fix to this or is this...
Ok, came accross this problem. After searching and searching, I downloaded the user guide ( who knew?! ) and the reason that is happening is because the Lumix DMC-FZ7 is not able to process an SD card bigger than 2 GB.
I switched it to a 1 GB and camera is back working!!
I hope this helps
Jul 15, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
When I took pictures to get the details of the subject in close up, it was blurry . my camera is canon power shop S51s
I am assuming that you did not set your camera for closeup work, which is why it was out of focus. Try setting for closeup (tulip icon usually) and see if that does not solve the problem. If you did set for closeup it is possible that the lens is dirty or smudged which will cause focus problems when doing close in work. Hope this helps.
Nov 25, 2010 | Canon Cameras
Auto focus does not work. no af assist lamp camera is DMC-FZ7
you can use a laser pointer or mini flashlight point at the subject to replace the AF assist lamp. When the AF locked, turn the light off then press the shutter.
Apr 06, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
DMC-FZ7 Panasonic digital camera won't focus when zoomed
Your camera focus problem mostly deal with machanical parts. So changing them easily will solve the problem. But unfortunately you may not do it yourself. Because it is highly complicated process. In deed it needs lots of repairing devices which are found only in services. According to me the service had given you the best answer. Please accept their advice. Good luck.
Mar 04, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
The auto focus and the manual focus are not
I have a similar problem. The focusing joystick has just stopped working. Been trawling the net for weeks trying to find a solution (out of warranty, typically). Have you had any luck solving your problem?
John
Oct 19, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Z740 cannot focus on long-distance indoor shots
Have you tried changing the mode? ie portrait, closeup, macro etc?
Jun 19, 2009 | Kodak EasyShare Z740 Digital Camera
Close up shots won't auto focus.the lens trys to adjust but the final setting is out of focus. the camera works fine on subjects at least 2 feet away
try using the little throttle that is located just below your on/off switch. if you push that either up/down, it should help you manually focus your subject. It is actually a really fun feature to play around with.
Feb 28, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Instruction manual
I have an FZ7K, here’s what I do:
#1. Set the mode dial on top of the camera to “A”.
#2. Set the aperture to the smallest f/number possible, f/2.8, f/3.2, f/3.3.
#3. Now take pictures standing as close to the subject as possible, (or zoom the lens).
For even better results, have the background farther away from your subject.
Aug 20, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
236 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
