Sure, they can be downloaded easily by using this software: Driver Update Software for XP Vista 7 8. Wish you best of luck. Cheers
Here are the instruction for installing the QX3 (or QX3+)
Microscope with Windows 7. You must be using a 32-BIT VERSION. The QX3 is not
compatible with 64-bit versions of Windows 7 or Vista.
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Before you run the programs below, right click the icon, click on
"Properties", click the "Compatibility" tab, check the box
next to "Run this program in compatibility mode for:", then choose in
the drop-down box "Windows 98 / Windows ME". You should also check
"Run as Administrator" if your account is a "Standard
user".
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/qx3plus
or
http://downloadcenter.intel.com
/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&
amp;strOSs=All&OSFullName=All%20Operating%20Systems?=eng
Step 2. Download and install the QCODINSTL.EXE software from:
http://tinyurl.com/QCODINSTL or
http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=160&DwnldID=2089&agr=N&lang=eng&PrdMap=160
Step 3. Download and extract the QX3 Drivers from:
http://tinyurl.com/IntelQX3driverXP or
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears you will see a message
saying that the driver installation was not successful. Click the Close box.
You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver
software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The
driver software should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
I can't install QX3PLUS.EXE software on 32-bit win 7. I would like to share my good experience on this as my thanks to this comment's author.
As a workaround, you would try to install a windows xp on your computer and then only just install QX3PLUS.EXE. all go well. My kid will begin to have a tour with this old toy.
This is kind of roundabout and techy but works really well and is useful for other things. You should expect to spend about 4 hours to solve this in this way.
I run Linux on my Windows 7 system this way and I run XP on my Mac this way. The main drawback is that when it runs it draws RAM from your primary system. From XP point of view, the amount of RAM and hard disk space is a luxury.
Friends if you don't mind spending a little money to upgrade to windows 7 you can try this link: http://windowkeydownload.blogspot.kr/2016/05/how-to-get-windows-7-for-free.html. The key works 100% and its price is cheap. More importantly, you have no need to worry about the risk of virus.
Activate windows click here: www.acyberkey.com
you can find the keys you want in a low price that you have never imagined.
SOURCE: I need the driver for my Intel Play QX3 for Vista
This works on my Vista system.
Instruction for installing the QX3 Microscope with Vista
Step 1. Install the QX3+ downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL Codecs software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
SOURCE: I have a Intel Play
Hi
I looked up for the drivers for your Intel Play QX3 Microscope on Intel's website.You can check this link
For the time being the driver has not been released for this device.Last driver update was on 8/28/2006 which was before the launch of windows 7.We need to wait for the compatible drivers or use this device on windows XP platform
Thank you
SOURCE: need qx3 drivers for windows 7 64 bit
The Intel QX3 is not compatible with 64 bit operating systems. It will not work. Sorry.
You can either reinstall Windows 7 as a 32-bit version or purchase a QX5 model which is compatible with Windows 7 64-bit.
-Mark
SOURCE: vista driver for Intel QX3 Microscope
Instruction for installing the QX3 or QX3+ Microscope with Vista
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
SOURCE: can't locate driver for intel qx3 for windows 7
There unfortunately isn't one available. They only made Window 7 drivers for the Q5 V2 version of it.
user".
or
software"
