Sir i hv a nokia 6020 model....i want to reset its factory setting but i unable to reset it bcoz when m entering its default setting code its showing error....
so plz give me a solution to restore it....
thank you...
You can try 1234 or 0000 these are default code for Nokia Phones..If these code not work,get the Free master reset code from the site Unlock-free.com/nokia/nokia-6020.html and reset the Nokia 6020 from security lock.
Usually the default security code is 12345. Go to the Menu, scroll to settings and goto restore factory settings, select restore all or restore settings only. Press Cont and enter the security code.
hi, go to main menu then >SETTINGS >RESTORE FACTORY SETTING >then enter your security code...if not change ,the default code is 12345 ...wait until the phone reboot and its done.. i hope it will help you ,thanks for trusting fixya
Remove the battery and the memory card from the phone,check for corrupt files on the memory card with a scan on your PC- card reader. Remove and format if necessary. Reset battery and open menu settings to open link to restore to factory settings- now type 12345. If this wont work then you must reinstall the software. check with Nokia care.
You can try to reset the settings to factory defaults by entering *#7780#. If prompted for your lock code, that will be Nokia's default 12345 unless you've changed it.
In order to have the phone hard reset, you'll need to take it to a Nokia Care Point. It is not resettable by end users.
Good luck and thank you for using FixYa! We sure appreciate 4 star ratings for the FREE answer to your question. Happy Holidays!
Yes i can help go onto your main menu and click onto TOOLS...then click SETTINGS .. then GENERAL.. go down and it will say Factory settings click FACTORY SETTINGS.. it will then ask you for a code teh reset code is 12345! hope this helps :) your phone will automaticly re start but may take a few minuits to re start dont panic just let it load and it sould be fine howere avoid doin this to often x
Open the menu then go to setting. Then scroll down go to restore factory setting and open it then enter the security code 12345 if you dont have change its security code. But if you change it the type your own code. Thank you.
Menu > Settings > Restore Factory Settings > enter the security code
The default security code is 12345. If it doesnt work remove your battery for 15min and try the code again. Still the same?the code has most probably been changed. Dont remember the code?Best to refer to a Nokia Service centre for a code reset :)
give me your imei no get it by pressing *#06# i will give you master code
