JVC AV-32260 32" TV Logo
Anonymous Posted on Dec 22, 2010
I have a JVC AV 31BP6 tv. The picture does not work but the sounds does. I tried to hook up a dvd player and I did get a picture from the video imput for a short time, turned off the tv and back to no picture but sound is fine. I took the back off of the chassis and looked for solder points that may have loosed up, didnt see anything, no burn marks or anything out of place. Should I junk it or do you have any ideas what to check? I am very handy, I know how to read a volt ohm meter. I also know a tv can hurt you too. Greg
  • 1 more comment
  • Anonymous Dec 23, 2010
    Thank you sir, I guess I'll look for a wiring diagram to find the parts you describe. Is that someting you cam pint me to? Or do I need to add more funds. It is an older tv, I just like to fix things.
    We'll see how it test out, I think the solution makes sence, even though the unit never moved, I know the solder joints do degrade in tv's due to heat. I'll let you know. Thanks again.
  • marvin_magan
    marvin_magan Sep 30, 2012
    check on flyback heater pin trace the line the first resistor should 1.5 homs
Anonymous
Level 3:
  • JVC Master 6,771 Answers
  • Posted on Dec 22, 2010
Anonymous
JVC Master
Level 3:
Answers
6771
Questions
0
Helped
1777328
Points
21413
Greg! you may have bad connections on the main board, flip the board over and carefully check the solder points, flybach transformer, horizontal driver transformer, video circuits to name a few, if you are handy with soldering iron all the better, some solder joints are hard to spot so use iron anyway. Make sure you resolder the parts that I have outlined even if the solder looks good.
How to hook up technics sh-ge70
Normally the turntable is connect to the amp via phono inputs on back (RCA connectors) the tape out to equalizer and equalizer out to tape in on amp. The equalizer does not have phono preamp. The equalizer may not clean up record scratches ,or pops or record track noise.
good luck
Hello, I have a JVC TV Model #EM302T We are trying to play a DVD on it. We get sound but no picture. What are we doing wrong?
For a dvd player you will need to use 3 cords. The 2 cords you talk about are probably the left and right audio cords which are red and white. You will need the yellow cord for video.
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Video Imput port not working...
Regardless of the possibility to repair the composite (yellow) input you would be better off using the component video input as this input allows much better resolution.
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Help
What video out put you connected between JVC player and TV ?
Look at back of your JVC player for Video out (yellow color) pin, hook RCA cable there and plug it to Input-1 or 2 in TV.
Now select AV 1 or 2 (what ever you hooked) in TV by remote and hopefully picture will in TV.
need further help, let me know model number of your TV.
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Hooking dvd player to tv
check if your dvd video output is switched to the svideo or RGB and make sure it is switched to the output youare connecting video cable .
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
