Question about Dewalt 7.2-18.0 Volt One Hour Charger
When I plug in my Dewalt fast charger ( model# DC9310) the red ligth comes on for a secon then goes out. Whe i place the battery in the charger the light still stays off and rhe battery doesnt charge. I tried another battery and the same thing happens. I then went out and purchaseda new charger and the same thing happens. could it be that my Batterues are bad even thoug onestill has alittle charge left in it and they're hardly ever used.
  • mikercase Dec 22, 2010
    How old are your batteries?
  • 675 Answers
The batteries are probably bad...especially if you kept them outside in the cold or at some point they got frozen...also, if you don't use them for a long period they will exhibit this behavior..get new batteries
Posted on Dec 22, 2010
  • aminajone Dec 23, 2010
    cdzfv dfgaer erga dfvd
6ya staff
SOURCE:
Wiring diagram charger
Request a wiring diagram directly from DeWalt.
Sep 28, 2017 | Dewalt Drills
When I place my 20 volt 3.0 amp Dewalt battery on charger,the red light comes on and then goes off. It then remains off. Is the battery bad or is it the charger?
Most likely it's the battery.
If you can find someone else with the same system then maybe they could check it for you. Unfortunately, you have the 20 volt system which isn't nearly as common as the 18V.
Or you could bring it to someplace like Batteries + Bulbs (If you have them around you) and they will tell you what's not working.
Oct 03, 2016 | Dewalt Drills
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
Feb 28, 2015 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
DC9310 charger was pluged into a 220v by mistake. What fried and can I replace it?
Most likely all of the power control circuitry, charging circuitry, and voltage regulating circuitry. At this point, your best bet would be to look for a used one on line.
Sep 04, 2014 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Dewalt de0245
These de0245 chargers are designed to detect certain problems that can arise with battery packs which would be indicated by the red light flashing at a fast rate.
If this occurs, re-insert battery pack. If problem persists, try a different battery pack to determine if the charger is OK. If the new battery charges correctly, then the original pack is defective and should be returned to a service centre for recycling.
If the new battery pack gives the same trouble indication as the original, have the charger tested at an Authorised Service Centre.
If you need new battery for this tools
Mar 23, 2014 | Drills
Problem with hitachi chargers
I live by hitachi, one of the good things about it is lowes will exchange them as long as you have a receipt and it's under 30 days. If not chargers are not very expensive, or you can send it back for repairs. I have 10 of those combo packs and never had a problem with a single one, for you to get 2 is a freak accident.
Dec 14, 2013 | Hitachi WH18DLP4 18Volt Lithium Ion...
18 volt dewalt lithium ion battery charger stopped working for no reason....
This can happen if the battery is too dead for too long. Keep trying to make it work like you have maybe 20-30 times. Or you can leave the battery in for a few days and let the logic chip do it's job. It should start working in a day or two.
Apr 25, 2012 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Delta CL 180 model charger turns on when you plug in and the yellow light comes on but when you put the battery in to charge the lights go out?
If all lights go out after the battery is inserted, the charger has entered pre-charge mode. In approximately 5-10 minutes, the orange and red lights should turn on indicating that fast charge has been initiated. If all lights remain off after 15 minutes, remove the battery. The orange light should glow. Reinsert the battery. If the orange light goes out when the battery is inserted and all lights remain off for 15 minutes the battery should be replaced.
Hope this helps.
Apr 09, 2012 | Dewalt Drills
Have just got the Dewalt DE9116 charger.Plugged it in & red light comes on & then goes off.Is the charger working properly?Have no instructions
that is normal it happens when u plugged and unpluged. after a second it should show no blinking. then when u insert the battery pack it would show the diagnostics. with the blinking pattern.
if you need the manual , you can get at www.dewalt.com or call us at 407 657 0474 and we can fax it to you.
Sep 23, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
De walt de9118 charger
when charger is plug in to ac it will blink once.normal voltage out for the unit in between 36v to 55 volt. the reading u have is normal.
Aug 07, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt 7.2-18.0 Volt One Hour Charger Logo
725 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
