SOURCE: software malfunction
I assume they told you to uninstall the software, remove the adapter, then re install driver an re insert adapter, as this normally cures the driver fault. If they didn't try that, if the problem persists the adapter may be faulty although i think it's a software problem. Try not to use Windows to repair connection as it never works and resets your pc's ip address differently than your routers already given it.
SOURCE: SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
SOURCE: wireless network on and off all time
Plz check ur signal strength first. Second u can check with configure ur wirless adapter properties with static speed (802.11b or 11Mbps).
u can check ur wireless adapter on ur bro's laptop, disable his WiFi button & connect his laptop through this wireless adapter to samsung modem.
If the problem remain same on ur bro's laptop then ur wireless adapter having some problem.
PLZ GIVE RATING BY YES or NO.
SOURCE: SMC EZ Connect(tm) g 802.11g Wireless USB Adapter doesn't work
Try this site
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_USA&knowsPartNumber=false&productCategory=5&modelNumber=585&partNumber=3203&downloadType=0&os=0
If that doesn't work go to SMC.com click the support tab and follow the instructions.
SOURCE: internet doesn't work despite correct installation of adapter
acer travelmate2200 has no wireles set up..
