Send the model number next time.the pump is blocked.if your model has the removable filter in the middle of it you have to remove it and clean it out.with a shop vac vac out all the water in the tub,then turn the filter counter clockwise and when the water starts coming out slowly vac it up until all the water is drained,remove the filter and clean it out.add some water and set it to drain and see if the pump works,if it does then you're all set,if it doesn't remove the filter again and make sure nothing is stuck in the pump,if it's clear you probably damaged the impeelar on the pump and need a new pump but they are pretty hard to brake,if it doesn't have the filter pull off the hose and vac out the pump then stick your finger in there or a screw driver and make sure the pump is clear,also check the hose to make sure that's clear,if it doesn't drain most likely you'll have to replace the pump.if you need more help let me know and send the model number,open the door and look around the opening of the dryer not on the door and you'll see the model number
