Acer Aspire 5050-3242 Notebook Logo
Posted on Jul 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"Finger Print" sized shaded area on screen
Located on upper left rurning across toolbar. what is this?
Anonymous
Level 3:
Genius:
  • Master 2,028 Answers
  • Posted on Jul 04, 2008
Anonymous
Master
Level 3:
Genius:
Answers
2028
Questions
6
Helped
830628
Points
5064
A shaded or dark spot on the screen is usually a bad pixel area and is caused by being hit or pressed to hard in that area. It could also be that the liquid crystal (LC in the LCD) in that area has become stagnant, try rubbing the area and around the area pressing firmly, just enough to see a color change in the screen area, but not too hard that the area turns black. Rubbing the area will move the liquid crystal around and sometimes refreshes a darkened area. If rubbing doesn't work, then it's a bad pixel area, and will eventually become a dead pixel area with time.
Font size change
If you are printing from word open up word select view from the drop down list select toolbars select standard formatting
Open up word across to the left you will see arial times new roman arial black next will be more to name a few of the different languages from the drop down list your documents will be read in next to that will be a drop down list with all sizes you can change the sizes of text
Open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
If its a web page
Right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the VIEW tab from the drop down list will be a Zoom with percentages %
Print size has changed . too small
click File on the upper left of the screen, then Print Preview. Look at the "scale" tab along the top toolbar (of the Print Preview page) and make sure you set it at 100% for normal size or more or less as desired
Want to increase size of print
if you are using word open up word select view from the drop down list select toolbars select standard ,formatting
also open up word across to the left you will see arial,times new roman,arial black next will be more to name a few of the different languages from the drop down list your documents will be read in
also next to that will be a drop down list with all sizes you can change the
sizes of text
open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
if its a web page
right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
if you need more help with this post a reply
hope this helps
Trying to enlarge print
also open up word across to the left you will see arial times new roman arial black next
sizes of text
if its a web page
hope this helps
Print size too small
select file in the top left hand corner then select print preview from the drop down list there should be another drop down list in top left hand corner with percentages
30%
40%
50%
etc....... this is on a web page
the same should be on the page if you have made a word document
if you are using word open up word select view from the drop down list select toolbars select standard formatting
sizes of text
if you are using a word document to open it on the top select the format tab open it then select font you can change your settings there also across the left you will see a stencil and an A which have drop down lists of color changes for background and print
hope this helps
I want to change my font and the size of print -Desire ARIEL and print size 12
if you scroll to the top toolbar (top of screen) you will see the view tab select that then from the drop down list you should see a zoom with % and a text size with largest to smallest
if you dont have these in the toolbar you will need to add them
right click in the toolbar select menu
also next to that will be a drop down list with all sizes you can change the sizes of text
when you want to print opoen the document select file then from the drop down list select print preview you could select edit then click select all and change the size of your print
hope this will help you
How do increas the print size in my computer?
open a document you want to print select file in the top left hand corner then select print preview from the drop down list ther should be another drop down list with percentages
30%
40%
50%
sizes of text
hope this help you
9helpful
Music player shortcut will not go from homepage on my mobile
Hi, just open your toolbar on the left hand side of the screen. Keep your finger on the music player shortcut and slide it across into your toolbar and it should move across into your toolbar. This worked for me ok. Hope this helps. Arnie.
1helpful
I have dv9000 notebook computer. how to config there finger print password
1. In Windows, double-click the VeriSoft Access Manager icon in the notification area of the taskbar.
2. On the “My Identity” page, click Log On, located in the upper-left corner of the page.
The VeriSoft Access Manager Logon Wizard opens.
3. On the “Introduce Yourself” page, enter the user's Windows password, if one has been established,
and then click Next.
4. On the “Services and Applications” page, click I want to, and then click Register Fingerprints.
NOTE: By default, VeriSoft Access Manager requires registration of at least 2 different
fingers.
5. When the VeriSoft Access Manager Registration Wizard opens, click Next, and then slowly swipe
your finger across the sensor.
NOTE: The right index finger is the default finger for enrolling the first fingerprint. You can
change the default by clicking the finger you want to register first, on either the left hand or
the right hand. When you click a finger, it will be outlined to show it has been selected.
6. Continue swiping the same finger over the fingerprint sensor until the finger on the screen turns
green.
NOTE: The progress indicator advances after each finger swipe. Multiple swipes are
necessary to register a fingerprint.
NOTE: If you need to start over during the fingerprint registration process, right-click the
highlighted finger on the screen and then click Start Over.
7. Click a different finger on the screen to register, and then repeat steps 5 and 6.
NOTE: If you click Finish before registering at least 2 fingers, an error message is
displayed. Click OK to continue.
8. After you have registered at least 2 fingers, click Finish.
9. To set up the fingerprint reader for a different Windows user, log on to Windows as that user and
then repeat steps 1 through 8.
2answers
HOW TO ENLARGE THE PRINT ON MY PRINTER
In microsoft Word, when you select a scale, you select a scale to view the page at, you dont change the size of the font on the page. to change font size go to format(in the top toolbar) > font. or use the drop down box in the toolbar that's located next to the paragraph tool(bold, italice, center, etc.).
~gnomer
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
