Check continuity across two pins on drill that get power from battery. If they are 'touching' or have continuity the drill is bad. It sounds like that is the case as two batteries did the same thing. Can you try the batteries in any other 18v dewalt tool? Borrow a friends if you don't have any other tools but see if batteries do the same.
Also, measure power of battery before you put it in and see how much the afterward you had it in for a second how much power it has. If it is shorted in the drill it will drain power. Sounds like a short inside drill. GL
