You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
SOURCE: ice maker will only dispence
what brand? I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
SOURCE: ice cube maker only dispences crushed ice no cubes
remove ice bin look at small square opening reach in with your finger and pull down on vertical rod if it doesn't come down you'll have to remove complete auger asm from freezer (remove 2 1/4 screws and unplug electrical connection lift asm up and pull forward ) set out at lest 24 hours for asm to defrost and dry out then reinstall auger asm
SOURCE: Will not dispence ice, crushed or solid cubes, will dispence h2o
Hi
If
the ice maker has completely stopped producing ice
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
and if the ice maker is producing ice poorly
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
SOURCE: the ice dispencer accumulates ice and clogs the
you have two problems. First the ice build up is because the dispensor door is not closing all the way and the air is causing condensation and freezing.
you will half to find out why the door is not closing. it could be a bad door or the solinoid could be bad.
The second problem is that the solinoid in the back of the freezer is not moving the ice bucket arm.
Common problem is that the solinoid is bad or the plastic arm on the solinoid is broken.
