I doubt there is anything wrong with the cards. Cards usually come pre-formatted, but you could try formatting them and see if it makes a difference.
However, I expect that your problem is down to compatibility. Many cameras, especially those that are a couple of years old, won't work with SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different. SDHC is not backwards compatible. Unless your camera's manual specifically mentions that you can use SDHC cards, you probably can't. I believe the largest capacity SD card is 2GB. Anything bigger will be SDHC.
