First right-click on the desktop and then left click on
Properties from the menu that appears.
The
display properties dialogue box will appear as shown in
fig. below, click on the
settings tab at the top right of the box.
The areas worth noting are:
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Screen Resolution This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.
Changing the ResolutionTo change your resolution simply slide the bar along to the resolution of your choice and then click the
Apply button.
After clicking
Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box, if you are happy with the way your screen looks then simply click
Yes, if you would like to try a different resolution click
No.
When you have finished simply close the Display properties box.
