Washing Machines Logo
Posted on Jul 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a ge wash machine model wwse6260 It starts to aggitate or spin and makes a shunk, shunk ?? noise.
  • trcreich Jul 05, 2008
    this machine has a transmission. where would the ball bearings be located if this is a problem.
    thank you
Anonymous
Level 3:
Genius:
  • Master 1,665 Answers
  • Posted on Jul 05, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1665
Questions
Helped
978919
Points
3981
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
isaac johny
Level 3:
  • Master 796 Answers
isaac johny
Master
Level 3:
Answers
796
Questions
8
Helped
241488
Points
2011
The ball bearings must have been worn out..
you need to replace them
Anonymous
Level 3:
Genius:
  • Master 1,142 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1142
Questions
6
Helped
444309
Points
3128
Since how long this is happening ?
  • 1 more comment
  • Anonymous Jul 05, 2008
    The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
    For correct part number you can refer to this website
    http://www.repairclinic.com/SmartSearch/...
My washer does not spin after the wash cycle . model ge gcwp1000ww
It sounds to me like the timer could be defective. Thanks
I have a GE washer (WBB4500G2WW) - wont aggitate or spin
The BELT... Part number wh01x10302
30% of the time is the issue here:
http://www.appliancepartspros.com/ge-belt-wh01x10302-ap3968432.html
Have a look at appliance-parts-pros (video guide)
http://www.appliancepartspros.com/repair-help/general-electric-washer-wbb4500g2ww-repair/wbb4500g2ww-pumps-but-will-not-spin.html
May require a specialty tool to mount the belt
(depicted in VIDEO... Sold on site): view here:
http://www.appliancepartspros.com/ge-service-kit-belt-wx05x20641-ap5957260.html
((not entirely convinced the tool is critical but the
Also check prices on eBay (top seller, free shipping
WH01X10302 AP3968432 1264395 PS1482278 WH01X10353 Washer Drive Belt eBay
Hope this holds off trashing your three year old washer...
Carnac the Magnificent
My washer won't spin or aggitate. I have a GE
Check the belt and clutch in the front under the lid run a butter knife under the lid and pop the front off and take a look.Have a great Thanksgiving.
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
2answers
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Washing machine problems
Sounds like the bearings in the drum may have failed, was it vibrating irratic on full spin before it stopped?
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
