When turn on my tv it's fine for 2 mins and then becomes dark and flickers and sometimes goes back to normal for a minute before it becomes dark and flickers again
For the past year when TV was powered on the picture would flicker a few times then go completely black. If the TV is turned on and off repeatedly for about 15-20 minutes itwould finally show picture. No problems with the volume just the picture.For the past year when TV was powered on the picture would flicker a few times then go completely black. If the TV is turned on and off repeatedly for about 15-20 minutes itwould finally show picture. No problems with the volume just the picture.
AnonymousMar 30, 2014
when watching it will flicker fastwhen watching it will flicker fast
The picture is strange and now it is showing black lines through the picture. If I push the input button, the input signs come up and the picture is more normal but very dark, then again the stripes start to appear after a few minutes. I hope you can helpThe picture is strange and now it is showing black lines through the picture. If I push the input button, the input signs come up and the picture is more normal but very dark, then again the stripes start to appear after a few minutes. I hope you can help
AnonymousMar 31, 2014
Dark on both sides and normal in the middleDark on both sides and normal in the middle
You can't post conmments that contain an email address.
ok, phoned a technician today and he has diagnosed the y/suss board as gone and 150 to fix but cant guarantee it will fix it for good, another board may go pop z/suss . so its the local refuse collection point for it.
Lcd tv sets are lit by small glass florescent tubes called cold cathodes and, are powered by: ballasts called inverters... these go out just like your office florescent lighting the parts can be purchased online from electronic parts houses and, are easily replaced
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
