SOURCE: Travelmate will not boot up
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
SOURCE: keys enter wrong characters
You have Num Lock on. Turn it off.Generally Function and End or one of those keys.
SOURCE: my keyboard wont type anything, the mouse works,
Somehow the left ALT key is stuck in a pressed position. Usually when you press left ALT and the letter underlined in a menu, it deploys that menu. In the File menu, the F is underlined and in the View menu it is the V that is underlined, hence the behavior.
Hope it helps.
SOURCE: i want to take the battery out of motherboard of panasonic cf-19
Pass is on BIOS :(
one year I don't used that LP :(
I try everthing :( but nothing
SOURCE: my Toshiba Satellite Pro A300-GR laptop wont type
You have Number Lock set on your PC - Have a look for a key top right hand side, it will have something like NumLck written on the KEY - you may need to use that Key in combination with the FN key - bottom left of keyboard - there should be a light somewhere on the keyboard which goes on/off as you toggle the NumLck key. You should see different coloured numbers on the key s*()UIOPJKLM These are the numbers and symbols that will be displayed when the NumLock is used
