This TV is less than 2 years old. When I turn it on I get the picture for about 30 seconds and then the screen turns completely green. I change the channels, the input mode, turn the TV off and on and get the same problem again. All the setting show up on the tv, so it can't be the picture tube, and the cable channels change fine and I can hear the programming. Can someone help me understand this problem?
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
SOURCE: Scenium DLP quit recognizing cable signal
You may have inadvertently pressed some buttons on the remote to take it out of the mode to receive cable channels.
If you unplug the tv from the wall for a while, it may clear the error.
Step 1: Identifying Your TV’s Location
1. If your country is highlighted, press OK on the remote control.
If your country isn’t highlighted, press the up or down arrow button on the
remote control to highlight your country and press OK.
2. Use the number buttons and/or the arrows on your remote to enter your
zip code or postal code. Press OK when you’re fi nished.
Note: If your postal code contains letters, press the up and down arrow
buttons on your remote to enter letters, and press the right arrow button
to go to the next space. The left arrow button also moves the highlight to
the left.
Step 2: Confi guring for Cable
The next series of screens asks you about your cable setup. To supply your TV
with the correct TV program listings, the TV Guide On Screen system needs to
know if your TV is connected to cable.
Note: If you’re using a cable box, always leave it on so you can receive
program information.
1. If your TV is connected to cable, highlight Yes and press OK.
If your TV isn’t connected to cable, highlight No and press OK. (STEP 3:
Confi guring for Antenna appears–go to page 24).
2. If you have a cable box connected to this TV, highlight Yes and press OK.
Note: The next series of screens is very important because the TV Guide
On Screen system must fi nd the correct cable box information in order
to receive the correct TV program listings.
If you don’t have a cable box connected to this TV, highlight No and
press OK (STEP 3: Confi guring for Antenna appears–go to page 24).
3. Highlight the input where you connected your cable box to the TV, and
press OK.
If you select Cable Input, continue to step 4.
If you select any other option, go to step 5 on the next page.
Important Note: Your cable box can’t be connected to ANTENNA
INPUT if it is to be controlled by the TV Guide On Screen system.
try using the guidelines above.
SOURCE: the rca scenium / src
you need to replace the bulb. It costs about a hundered dollars and you can replace it yourself. refer to the lamp replacement instructions that came with your set
SOURCE: My RCA 50'' DLP Rear Projection TV will not turn on
Hi, This could be several things as the power goes everywhere. Long distance troubleshooting so hang in there. First try a cold reboot by unplugging and replugging after 30 minutes. If nothing check P1 on the light engine for the following voltages: pin 2 5vdc, pin 3 3.3vdc, pin 9 3.3vdc, pin 12 12vdc. If any of these are not good it is the formatter board. If all are good, does the color wheel spin at all. If this is OK then check J4 on the light engine, the ballast enable line should be 0 vdc in stby, .5 vdc at turn on, and 2.5 to 3.25 vdc in run. If good, is the light engine trying to fire the lamp? If not, inspect the J4 connector and the lamp power supply, If they look OK then the lamp ballast is probably bad. This will give you something to do for now, Good Luck!
