Question about Samsung Heating & Cooling
Hi, I have a samsung aqv18ja series split type air conditioner (cooling and heating) wall unit. the unit was install in 02/12/2009. By "one hour heating and air conditioning". In this short time service the outside compressor has been replace, the system has check and recheck,for cooling leak. the inside unit fan motor has been change. but the problem still exists. The inside unit fan continues to run when the unit is "off" and with the remote off.
  • 2,133 Answers
Simple, check in your remote. There is an option button "Blow". Just press it. Your unit gets completely off. Please write back if helpful?
Posted on Dec 26, 2010
6ya staff
SOURCE:
The system cannot be turned on. Need a tech.
[PDF]Service Manual - Quietside
https://quietside.com/max/.../Service%20Manual_MAX%20Series.pdf
Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.
Sep 28, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
Tip
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central air conditioning unit. They also are a very good alternative to window air conditioning units. I will explore the use of these units more closely and look at how they can be used effectively.
One of the many problems encountered by the professional is when they are asked to install central air conditioning in an older home that was never designed with air conditioning as even a possibility. The walls may be very thick stone. Often they have very little or no insulation. The floor structures may be rough cut lumber. The joists spacing may be random. Walls and ceilings are plaster and lathe. Basically everything is stacked against any type of ducted central air conditioning. Many log style homes also are not very easy to get any kind of ducted central air conditioning installed. The open ceilings and the bare log wall design does not allow for any kind of ducting. I'm sure there are other situations. These are the ones that I have come across most frequently.
If you have a home or building that falls into one of these categories you may want to investigate installing a ductless air conditioner. This type of air conditioner can be installed in almost any home or building. The small indoor unit can be attached to the wall with a few screws. Most of the units only require that a three inch hole be bored through the outside wall. In new installations the units can be placed on inside walls with some fore thought and planning. For installation in older homes or homes that are already built you will want to plan the units to be on the outside walls.
The outdoor condenser units can be placed up to one hundred feet away from the indoor units. One outdoor unit can be used for many indoor units. Up to four indoor units can be attached to the same outdoor condenser. Some very advanced electronics will control the operation of the condenser and compressor to supply the refrigerant to the indoor air handler units that are running at the time. With variable speed technology the compressor and the condenser fan will only run as fast as needed. This technology has become very efficient in the last few years. You do not have to give up any efficiency with these ductless split units.
Another advantage to these mini split air conditioners is that they can be controlled to run only in the rooms that you actually need air conditioning in. If you are not going to be in a room you can shut down the unit. The units also have timers that can be set to turn the air conditioning on or off at preset times. If you are not going to be home all day the air conditioning can be setback or turned off. The timer will turn on the air conditioning so that you return to a cool house. Central air conditioning is very hard to zone effectively. Also with large central air conditioning systems the outdoor compressor will be running at full capacity even though only a few rooms amy be calling for cooling. There are some central air conditioning systems that are do some staging and variable speed technology. These are not as efficient or as effective as the ductless split technology.
Ductless split heatpumps are another great idea to look at. For a few dollars more you can also very easily have heat from your air conditioning mini split. Then especially in the mild spring and fall weather you can have some very efficient heat with out starting up that big monster of a furnace or boiler in the basement. In southern climates the heatpump version of the ductless split system may provide enough heat year around.
Ductless split air conditioning is definitely something that can solve many problems for some homeowners. Add to that the many advantages of these units and you will find that they are worth every penny that you will invest into them. As with any project like this make sure that you screen your contractor. These units are not for do it yourself people. There are many things that need to be done correctly for these units to work properly and efficiently. A refrigeration license is also required to install these air conditioners.
By doing a little research and hiring the right person you will enjoy many years of trouble free service from your new ductless mini split system.
on Dec 04, 2009 | Heating & Cooling
RETAIL PRICE FOR ONIX REVERSE CYCLE SPLIT SYSTEM
contact shops that install units and get quotes. retailers generally have contractors that will give quotes for installation on new units.
Jan 01, 2015 | Heating & Cooling
CHH012CD-13B
This type of unit does not drain into the outside unit. It drains into a nearby interior drain, or just to the outside near Inside unit. If the unit is cooling properly, you're ok.
Jul 01, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
I have two of these units with remote located in one room. All of a sudden, both remotes work the same unit. How can I "reprogram" one of the remotes to control the other unit?
Here is a link to the service manual for your unit. Look for section on programming unit identification for the remote.http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCsQFjAA&url=http%3A%2F%2Fwww.quietside.com%2Fclassic%2Fdownloads%2FService%2520AQV18_24%2520JAKCV.pdf&ei=uwh1U5PpNM6iqAaHr4DQCA&usg=AFQjCNEAs6FdSrr1lSDgNuNZ_9zvmycdKA&sig2=pILXHK1-yJa9ugqScI1evw&bvm=bv.66699033,d.b2k
May 14, 2014 | Samsung AQV18JA Classic Wall Mounted Mini...
Hello We just installed a Sanyo KHS1271 mini-split
The condensate drain line was not properly installed. Make them pull the wall unit and correct the problem.
Be persistant until you are satisfied they have the problem corrected. Do not pay any additional money. If they do not correct the problem then report them online to the state board of heating and air. Fill out their requested complaint form and follow thru with a second complaint if you do not get total satisfaction from the contractor that installed the unit.
Hope this helps.
Sep 23, 2011 | Sanyo Split System Air Conditioner
I have samsung wall type split,working normally for some time then make a small beep indoor unit then the compressor turns off..
The unit is locking out...find out where to check the "code" that tells why... usually on the outdoor unit circuit board...
heatman101
Aug 28, 2010 | Samsung AS18A6RB Air Conditioner
My Samsung air conditioner which is of split type is not operating. It is of the AS185 series. There is a red-light that is on. This has never happened before. It turns on momentarily and turns off again...
After 15 months of used my Split type A/C model AS18F series suddenly not cooling, I unplugged the unit and clean the Air Filter as well, but still the problem exist.
Apr 19, 2009 | Samsung AW1003M Air Conditioner
Heating & Cooling Logo
245 people viewed this question
Top Samsung Heating & Cooling Experts
Marvin
Marvin
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
