there seems to be a problem with the control board as sudden switch off and on can cause the circuit board to fail contact your nearest repair person and ask for a quote eric
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
57.x FAN FAILURE CALL SERVICE
Control Panel Message57.x FAN FAILURE CALL SERVICEEvent Log Error
Service Messages:
57.01.00
57.02.00
57.03.00
57.04.00
Required Action
A fan motor failure occurred. All fans are enabled to low speed operation at printer power-on. Fans will go into high-speed operation during the print cycle. All fans are disabled during PowerSave Mode.
x = 1: FM1 (Laser/Scanner Fan)
x = 2: FM2 (Power Supply Cooling Fan)
x = 3: FM3 (Formatter Fan)
x = 4: FM4 (Face Down Deliver Fan)
Cycle power. It the message continues, check and reseat cabling between the fan motor(s) and the DC Controller PCA.
sometimes if these machines are running during power failure they get lost in thee own programmin g
this particular machine is notorious for it
unplug the amchine and let it sit for a few minutes
plug it back in and you should be good t5o go
Service Messages:
57.01.00
57.02.00
57.03.00
57.04.00
Required Action
A
I had the same problem. It turned out a power transformer in the neighborhood had gone bad. I found it by checking power at the receptacles in the house and we weren't getting proper voltage throughout the house. We had enough power in the house to power lights, the TV, coffee maker etc. but not enough for the dryer. I called the power company and they came out to do a check. At first they said there was a wiring problem with the house until all the neighbors started coming over after seeing their vehicle and saying they were having problems. So maybe you aren't getting proper power to the unit.
