Question about Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE 5D AND F21 ON THE WHIRLPOOL DUET FRONT LOAD
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel.HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws.Once the screws are removed the panel should drop down, and then pull off.If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump.It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap.BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here?s a helpful way of quickly removing the residual water.If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac.This will empty the wash tub, pump and drain lines.If you don?t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle.Allow the towels to soak up the majority of the water.Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained.Check the drain pump for foreign objects and debris.Check the pump impeller and make sure there?s nothing caught in it.Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover.Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT ? DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console ? DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button).?C00? will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills.The pump is gravity filled and will hold water even it is not pumping.Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times.The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket.This is why it is important to leave the door ajar when not in use so this water does not become sour.
Posted on Dec 26, 2010
6ya staff
SOURCE:
ERER CODE 5D?
Whirlpool Duet Sport ht 5D/F21 Error Fix - YouTube
? 5:40
https://www.youtube.com/watch?v=2dV3FLzWPTM
Aug 6, 2013 - Uploaded by Mariela Gonzalez-Aroche
Steps in this video may be used to repair both F21 and 5D error codes. ... which is located on the bottom right corner of thewasher machine.
Nov 01, 2015 | Washing Machines
F21, 5d, and not working
remove the bottom panel 3 scres and you will see it check the filter there for a blockage
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
5d error code
It may have F21 code together meaning long drain in the system. Open the small top toe part then will see the pump. Open the filter and clean the pump.
Oct 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore HE2Plus - it is 6 years old. All of a sudden two days ago I got up to a load of laundry not done, full of water and the code F21. We have gone through most all of your suggestions. At...
The Sd code appears when sud is detected but it may also indicate draining problem such as blocked drain filter or broken drain pump as signified by the long drain error code F21. The drain pump impeller may be broken or restricted resulting in poor draining or no draining at all or the drain pump motor is faulty. Since the drain hose and filter have been cleaned but the error code still persists, the drain pump likely needs to be replaced. Click on the link below for the detailed troubleshooting instructions.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing
Jun 18, 2011 | Washing Machines
Error F21 with humming sound, then goes to Error 5d
Yes, your F21 is a clogged drain.
Remove the front panel. Unscrew the drain cap and clean it.
Apr 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21, 5d, and now not working
I had to call the Whirlpool service man. He came and concluded that the control panel was the culprit. He said it could be that the contacts were bad, but he didn't want to unstack the washer/dryer (dryer is on top of washer) to check it. He was suppose to call me to day with a price for another control. I'm just going to go and buy another machine. Can you recommend a reliable front loading washer?
Thanks for all your help!!!
Judy
Whirlpool Duet GHW9150P Front Load Washer Logo
1,352 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
