yeah, I'm looking for Part Number for RICOH Aficio MP C3000 Fuser Assembly Unit (220 Volt)yeah, I'm looking for Part Number for RICOH Aficio MP C3000 Fuser Assembly Unit (220 Volt)
AnonymousMar 24, 2014
code sc302code sc302
You can't post conmments that contain an email address.
Seems its fuser assembly fault.
Fuser assembly is a part to fix toner image permenentely with the help of hot rollers on media. The temparature varie depends on model, in case the temparature not reachess specified level you may get image fixation problem, the same what you are facing. Replace fuser assembly.
The line in the middle of the page is caused by a damaged or worn fusing assembly in the printer. Here is a link to an article showing this issue on the Laserjet 2100 printer and how to replace the fuser unit. Your printer just needs to have the fuser replaced, it is part number RM1-6405 and is available from Amazon
These machines use oil supply units located on top of the fuser unit. They are not refillable order another and replace... continueing to run this machine without fuser oil will cause the fuser to fail and copies to look terrible
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
its very useful to me thank you so much.
can I have part Number for RICOH Aficio C3000 please?
code sc302
