Dishwashers Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Kenmore ultra wash dishwasher fills with a little bit of water but does not spray water and does not proceed through the wash cycle. Any advice? We had problems yesterday with blinking lights and not able to get anything to work except the drain. then we followed a sequence of pushing buttons and it solved the first problem.
Benjamin Patri
Level 3:
  • Master 3,037 Answers
  • Posted on Dec 27, 2010
Benjamin Patri
Master
Level 3:
Answers
3037
Questions
7
Helped
706738
Points
8239
The spray arm rotates based on the water pressure coming out of them. If no water pressure, then no rotation. You probably have a clog on the intake hose. You can pull out the dishwasher, tip it forward so you can get to the bottom and then remove the intake hosing to check for debris that might be clogging it. Also check that the arm will spin freely if you spin it by hand, it should.
Let me know what you find. Have a great day.
Benjamin
2answers
Whirlpool dishwasher not spraying water during wash cycles Model #: WDT730PAHZ0
Check water pump and make sure there is no bloks in the pipes try using a good dishwasher cleaner and if its got the turn bit on base inside open it and make sure filters are clean blessings
4answers
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
1helpful
Kenmore dishwasher: Pre-wash cycle is too short: fills with water, runs for only one second, and then drains. The rest of the cycle is fine; the dishes get clean.
Pre-wash may be compromised and a new power circuit board may be needed.
My advice: As long as the other cycles are accurate and work as usual; Pre-wash in your sink (spray off waste material) before you place the dishes in the washer and commence cleaning. Its best to wash off food and other material before washing in the machine to avoid clogging the drains and pump.
We just installed a new kenmore dishwasher yesterday. Model 13242 It has been running for almost2 hours and is still on the washing cycle--no water in it however--is this normal? I'm in a bit of a panic as...
THAT IS NOT NORMAL!!!!!!! A normal wash and dry cycle will take approx. 2 hours in length including drying cycle.
You should see that water has been present in the machine within the first 2 minutes of the start of the wash cycle, you should also be able to hear the water entering the wash tub.
The fill valve or water supply seems to be the issue, if the water doesn't enter the tub then the controller won't proceed witht the wash cycle. Double check your water supply tube / hose to make sure there is water present at the connection to the dishwasher.
GOOD LUCK !
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
3helpful
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
15helpful
2answers
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 • Dishwashers
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
