I have an older maytag washer model # MAH3000AWW.. my problem seems to be with the spin portion of the cycle...when it reaches that point I can hear the pump expel the water but the drum does not spin...what is my problem? timer? circuit board? door lock sw? please help...
Lock light does not come on and machine does not spin. I have replaced the wax motor and the lid switches but it still doesn't spinLock light does not come on and machine does not spin. I have replaced the wax motor and the lid switches but it still doesn't spin
You can't post conmments that contain an email address.
Could be just about anything. It's all designed to prevent it from spinning if there is a problem. If the motor is still turning, but never gets up to spin speed, check the out of balance circuit. There are two cabinet strike switches and an inertial unbalance switch. Or check the door latch assembly, it's possible for the door to lock enough to turn the 'door lock' light on, but not move far enough to actuate the 'spin enable' switch. Maytag has upgraded the motor/ motor control board for the older Neptunes. If the motor is not running at all, check that the main control board is sending power to the motor control board. If it is you need the motor/ motor control kit (just one part #) If the main board is not sending power to the motor control board, you need a main control board, but you still need to test the motor control board. Take a test cord and put 120 volts to the motor control board, the motor should start turning at 50 rpm (normal agitate speed) if it doesn't you would need the motor/ motor control kit as well.
Time for a new machine. It is likely to be the timer. Many parts are discontinued, but there is a replacement timer for $312.48. The information is conflicting to the part it replaces though so you will need a service call.
Timer
Part #22002277
The manufacturer no longer makes this part, and there's no substitute part
#9A
Control panel Diagram
Timer
Part #22002338
Replaced by #WP22002441
$312.48
it could be a balance problem. Most machines are programmed to abort fast spin if the drum is unbalanced. This can be caused by too much in there, or possible the contents have clumped together somehow. Try a spin cycle only with an empty machine and see if it reaches full spin
most common issue with these is the door lock assy. You need to remove the control panel and check the R11 resistor on the board most likely it will be burnt. This was a common issue a few years back. If the R11 resistor is burnt you need to replace the door lock AND control board or your problem will occur again.
take off the panel above the door,there is a micro switch next to the light put meter on switch and read it out,use a screw driver and push on switch while your checking for continuity,if that switch checks ok change out the enersia switch,take off just the right side of the boot and remove right side white cover and you can reach this switch
That is a common issue that is caused by the control board of the machine. You may need to request service to fix this issue. Usually it may be caused by a resistor. Replacing the resistor may make the machine to work for a while but the repair will not last longer. I believe that the machine control board next to be replaced. Something else may be causing the control board to go bad.
Perhaps you were able to feel a burning smell from the washer machine in previous days.
Standing water may be caused by the control board failure because the pump will not operate properly.
