The button for this is on the right, the second one from the rear and it has multiple squares on it for a symbol. Pressing and holding this button down then turning the rear dial should change the shutter release function. It cycles through single shot, multiple shots low and high speed, and then self timer. You set the actual parameters of the self-timer from the custom setting menu.
Are you holding down the release mode button (marked with overlapping rectangles) while turning the main command dial (the one on the back)?
