Photo tray problem
' Lift the output
tray up and verify that the photo tray ' is pushed in until it stops, then lower
output all the ' way down. Press OK
button on the printer to 'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper
tray and photo tray
3. Remove output
duplexer (on back of printer)
4. Open input sheet
feeder (on top of printer)
5. Open cartridge
access door. (Basically lift up control panel and scanner section of the
printer)
6. Turn on printer
(Power button on now raised control panel)
7. Printer may
display message "Performing printer alignment - Do not interrupt"
8. Wait for a few
minutes until printer stops making all setup noises.
9. Close cartridge
access door, close input sheet feeder, replace output duplexer, insert paper
trays
10. Do a test print. All should be fine.
Hi
Error code C1183 means finishing option elevator drive malfunction. It appears due to tray lift motor failure on the finisher. To trouble shoot the issue turn off the power and open the elevator section to check the elevator motor. Wait for 2-3 minutes and check if the issue is resolved. If this doesn't work then check the alignment of front and rear rollers of the finisher. Also make sure that the finisher exit guide rollers are fine & the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. Sometimes this error may appear due to a broken lower gear by the pin slot. Hope this helps...
Daniel
