Fuji FinePix A400 Digital Camera Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i find the driver for the A400 for windows 7?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Fuji Master 102,366 Answers
  • Posted on Dec 27, 2010
Fuji Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443774
Points
622693
You can download software and drivers from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a400#DriversAndSoftware
You might want to consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Not possible to tranfer data to computer, OS Windows 7
What does your computer say about it? Does it pop-up a window that says something?
5 m pixels drivers
I found the official support page for your camera (Samsung Digimax A400).
Click here and you will be taken to the website. Links are available for manual, driver and software.
I am facing e18 problem.Need to open a400 camera.Tell me the steps.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try. And for the A400, have actually had a lot of success with these, especially Fix #7.
2answers
Reqd Driver Software for anon Digital camera Powershot A400
Find the Software disk for the PC and install it. Make sure the camera is off, then connect the usb cable. Then turn the camera on in the playback mode.
1helpful
I do not have CD for installing driver for Samsung Digimax A400
no problem, go to the website: http://www.samsung.com/uk/support/download/supportDownMain.do
and follow the instructions on screen to find your camera and it will give you an option to download the drivers and other software avalible for your camera! (also worth doing this when you get home to make sure you have all the upto date drivers!!)
Driver update problem for digital camera
In order to get rid of the error, you have uninstall the driver, update your operating system with updates from Microsoft (see below for instructions) and follow these suggestions:
  1. Best method, copy the photos to the computer by connecting a card reader to the computer and plug the SD card into the card reader and transfer using your favorite software (like Picasa) or through My Computer.
  2. Drivers are not required for the A400 and Windows XP. So you can plug in the camera, without drivers and it should work. This appears to be the one that's not working, You need to un-install the drivers and either reinstall, try updated drivers from the links below, or don't use the drivers.
This information is in the manual on page 96. See this link for the manual.
See this link for details about the WIA driver.
About the error "driver update failed" rea
I personally have stopped altogether trying to get the drivers and software installed because they can cause more problems. I just transfer using a card reader.
If you want to use the software that comes with the A400, it's best to install ZoomBrowser, then you will need to follow to this link to get the update to this software.
Once this is done, reboot your machine to make sure the system is then up-to-date.
Make sure you have also updated your machine with Windows Updates. This is done by opening Internet Explorer and clicking on Tools | Windows Updates. Follow the links at their site to update your machine.
Forget the hassle of trying to get the camera linked to the pc with software etc....
Much faster transfer of photos and no hassles with a usb card reader works every time 'no drivers' to mess with.....
http://www.memorybits.co.uk/shop/card-readers/14-in-1-card-reader-plus-100-meter-bluetooth-dongle-/4314
Sony hmd-a400 monitor
Next time you get it running, right click my computer>properties>hardware tab>device manager and look for your monitor on the 'Monitors' '+' sign and right click>delete. Also check 'Display adapter' see if the correct driver is displayed. Re- boot and let Windows re-install monitor driver(it should list it as 'Sony')
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
