I have an Asko W620 Washer that worked fine before we weent out of town. We returned today and tried to do some laundry and the washing machine keeps filling up and doesn't stop - even if it is unplugged! Any suggestions?
Sounds like your fill solenoid has stuck in the open position. There are 3 #20 Torx fittings along the back and you can lift off the top panel. The solenoid will be in the back left side.
I would shut off your house water supply to the machine and then do a voltage check to see if the solenoid is remaining energized. Another more simple option is to give the device a few light taps as some debris may have become trapped inside and caused it to become stuck open.
