The WPA passphrase is the wireless router's encryption key. The encryption key is generated using a phrase which is used to generate a group of hexadecimal numbers.
If you use wireless WiFi, instead of direct ethernet cable connection to the Roku, WPA passphrase and WEP key are security codes used to keep unauthorized people from using your wireless signal to access the internet and possibly eavesdrop on your internet activity.
The WPA passphrase is the security code that you used to set up the wireless networking. If you can't find that passphrase you will need to reset the device and start over, including for all of your other devices.
Theencryption key secures your data from unauthorized access.
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key.
The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings.
To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the Xbox, laptops and orcomputers with these router's wireless settings. Then the Xbox, laptops and desktopcomputers can communicate with your wireless router.
To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers can communicatewith your wireless router.
Go onto your router's wireless configuration to get the Passphrase.
To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
To get the WPA passphrase of the Cisco Linksys E1000 Wireless N router, you need to have a computer that is wired to the device. Log in to the router's setup up page by opening a browser then type in 192.168.1.1 on the address bar. Leave the Username blank and on the Password type "admin". On the setup page click on Wireless then on the sub tab click on the Wireless Security. You will see then the WPA passphrase.
Hi Friend,
In this case I would like to tell you that the WPA passphrase is set in the router's page. So, you will find the passphrase on the router's graphical user interface.
however, I would also like to tell you that the WPA passphrase is the same key that you have set for the wireless network to connect to the Internet
The WPA security passphrase is stored in the wireless router's wireless encryption settings. You need to open the browser and enter the router's URL comfiguration IP address, login and go to the wireless settings.
For wireless security you can select WEP or WPA security. Some are specific lengths but within reason you can choose your own. Set in on the router first then on the computer. You may need to set up the router with a wired connection
Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
Beside the SSID option, enter the name for your wireless network connection.
Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
Click AES beside the Cypher Type.
Make sure PSK is selected beside PSK/EAP.
Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better.
Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
Click Apply to save your security settings.
Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
