SOURCE: Ice Dispenser problem on KitchenAid KSCS25INSS00 Refrigerator
You can download the repair manual or service manual for you Kichen Aid which you can find by using goolge just type
SERVICE MANUAL KITCHEN AID (model) Brand
and google it
here is a useful forum that contais extra information and some quick fixes http://www.applianceblog.com/mainforums/showthread.php?t=7374
SOURCE: ICe does not fall from KitchenAid KSCS25INSS00 Ice Dispener
remove the bottom tray that you sit your glass on, push down on the bottom of the trim arround the despenser, lift outward then upward on the trim panel, have a piece of duct tape handy to tape the panel out of your way to gain access to the assembly
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
SOURCE: KitchenAid Superba ice maker not dispensing ice
the problem is that the bottom piece is missing from the ice maker housing. i have the same problem and im looking for that peice
