SOURCE: Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
SOURCE: Hoover Nextra HNWF 3137 washer/dryer
I have the same problem exactly please send me the solution with confirmation of the exact part requested my machine is HOOVER HNL3137 1300rpm/7kg thanks
SOURCE: hoover nextra hnl 2126 washing machine
Click on your model number (below FIXYA) on this website, & search for your model, make. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is.................
Rate me pl if helped...................
SOURCE: water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged
drain hose or the water pump. You’ll need to drain the water out of the
base and also check to see if there's something
stuck inside the pump or the drain hose connected to the pump (pump is usually
located at the bottom and towards the back of the washing machine). If the
drain line isn't clogged, you may have a problem with the water pump such as a
frozen pulley or a broken impeller. If that's the case replace the water pump. Please
do accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
