Is it a constant squeak or does it go squeak-squeak - squeak as it agitates? It is a squeak that is intermittant then usually your brake is losing its hold. You will need a technician to do this job. It requires special tools that they should have. I repeat a technician should do this job. You can seriously hurt yourself attempting this repair. Also see if the inner tup is turning as it agitates, if it is then it i definately the brake. But one more time do not try this repair it is a dangerous repair that should be left to technicians. There is a spring that is under heavy compression that requires a tool to release it.
