Coby Dp-812: do I need somekind of "stick" to insert into the frame in order to download pictures? I seem to be able to hook up my usb port and download from my computer but all of the pictures are verticle & I cannot rotate them or save them. How do I get pictures downloaded correctly?
Most digital frames come with a USB cable to hook the frame directly up to a computer. When you plug in the frame, a drive should show up in your "My Computer" section (for Windows) or on your desktop (for Mac). In most cases, you just need to drag and drop the photos onto the drive.
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
You
can move them to another card (i recomend a cheap usb stick) just move
from the camera card to a folder in your computer and then copy them to
the usb drive/stick and plug it in the picture frame
* Please rate this solution with Thumbs up and comment to help us improve providing support
I read up on the specs of the frame and it does not have an internal memory, thus you will have to have the sd card inserted at all times to display photos.
Hello Sir #1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com # 2 Open up 'My Computer'. You should see it under the list of available drives. # 3 Check its contents first to make sure that you have the right drive. # 4 In 'My Computer', right-click on the drive and choose 'Format'. # 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place. # 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
you can move them to another card (i recomend a cheap usb stick) just move from the camera card to a folder in your computer and then copy them to the usb drive/stick and plug it in the picture frame
should be able to use a memory stick or card. upload from computer onto stick/card, insert into frame & will upload pix. some frames have a USB cord that connects directly to the computer as well, if so, you can plug it into the computer (& the frame), and upload the pix you want on the frame from there (sometimes there's a program on your computer that will assist you, sometimes you just do it manually).
If this doesn't help you, please see: http://www.cobyusa.com/?p=doc
This is the Coby website. You input the product & it will pull up all available documentation for it. Sometimes the manuals are available online.
If I've been helpful, please let me know w/ a scoring.
The Coby DP-887 does not have built in memory so one cannot "load" pictures onto it. It is a viewer in every sense of the word. If you load pictures on a flash drive or memoory stick and plug that into the Coby DP-887 then you'll be able to view pictures or video.
