Panasonic Lumix DMC-FZ7 Digital Camera Logo
Posted on Dec 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have tried a new sd card for more memory and it reads card error with every new card i try i've tried 3 different cards now and the original still works so i know the reader works but it just doesnt seem to want to read any other cards any ideas??
Anonymous
Level 3:
Genius:
  • Master 1,177 Answers
  • Posted on Dec 29, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1177
Questions
0
Helped
218857
Points
3782
You won't be able to use a card larger than about 1GB (maybe 2GB) in this camera. "SD" cards larger than 2GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
What formatting is necessary to play videos on the SD card slot of my Magnavox NB500MG1F Blu Ray Player?
The SD card is mainly for photos, but you can do video.
The SD card needs to be formatted as fat 16
The video has to be profile 1.1
If you use the larger SDHC cards, they can be formatted fat 32.
It works best if you format it with the player and not your computer.
Magnavox NB500MG1F Blu Ray Player: I've been having trouble getting the SD card slot to read the videos I put onto the SD card. I've tried everything from converting all the video files to AVCHD file types...
It is obvious to me that the player can't read the video off an SD drive. In my experience that card slot is for installing updated firmware not video material.
My Kodak DX 6490 will not read my 2 Gb or less SD Cards. It keeps recording to the camera memory. I will not play videos onto my digital TV. What should I do?
Hello, Have you tried formatting the memory card with the camera?
If a card is formatted with another camera or if it is new you should format it with the DX6490.Hope this helps.
Russ
1helpful
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
2answers
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Error on formating new memory card in camera error says memory card is full brand new card i tried 2 in faact same error kodak c310
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
I have tried 3 different Sd cards in my Norcent x125 DCS-760 camera. All 3 times I received a ''card error'' message. What can I do to fix this???
May i ask, have you formated these cards before putting them into your camera?
If not then the first step is to format your SD card through the camera menu. (Read your camera manual to see how to format your memory card). If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
Hope this helps,
Karlos
Jul 04, 2009 • Cameras
6answers
Can't access photos on 2 GB SD camera card.
You may try some photo recovery software to rescue the files on your digital camera sd card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
1helpful
Tom Tom XL
The One XL can only read from internal OR sd card...
So, if you want the device to boot from the sd card, it need system files installed on the sd card...
So, try this:
- BACKUP !!
- Copy ALL content from internal memory to sd card.
- Insert sd card, and boot the device.
It should know boot from sd card, not internal memory...
9helpful
2answers
Format Memory Card Error
The problem with the c350 is that it does not accept a memory card higher than 1GB! I found that out through the Kodak website and not in the User's Guide!
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
