Restore your iphone to factory settings this will solve your problem go and get this click here it will jailbreak your iphone and unlock it to any sim this gu will help you just tell him your problem and he will solve it he's a god with all things iphone.
FIRST YOU HAVE TO TAKE MY **** AND SHOVE IT UP YOUR ***
If your iPhone is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
For more ways, check: How to Unlock A Disabled iPhone with/without iTunes
Find your solution from the list,
Apple Iphone Smartphone
Codes:
Software & Hardware Problems
Find Your Solutions for other Apple Products:
Apple Iphone 3G
Apple iPod Touch Digital Media Player
esuh
What shall i do?
yeah but when i connect it to itunes it says it has a passcode.What i do na
my iphone says "iphone disabled conect to i tunes
my iphone says disabled connet to itunes..what does this mean??? how can i fix this problem?
IPHONE DISABLED CONNECT TO ITUNES WHAT SHOULD I DO
my iphone is disabled connect to iTunes
i have the same problem
