Vizio VW42LF 42 in. LCD HDTV Logo
Posted on Dec 29, 2010
Our tv shows a great picture through hdmi 1 but hdmi 2 our dvd player fades out after a few minutes, Does this with the Wii on the AV1 setting~ is this common and can be easily fixed?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
91
Points
Ours is doing the same thing. Did you find out what it was?
Audio not working on VCR side of LG LRY-517 DVD/VCR combo player
The back of the lry517 has 2 sets of audio outs and 1 set of audio ins. If you are using the component video outs, use the audio outs to the right of the component outs. If you are using AV1, it should be the audio to the left of the component outs.
The tape's audio may be very low, try turning up the tv volume? You could also try adjusting the tracking? Have you tried using the AV1 outputs? It would be Composite Video and stereo audio.
2answers
When playing a DVD, my Bose 3-2-1 DVD player's picture is not connecting to my Vizio Smart TV, only the sound.
  1. Make sure the video cables are properly connected. The cables that connect the DVD player to the TV should be securely plugged into the correct ports on each device. Double-check that the cables are not loose or damaged.
  2. Check the input source on your TV. Make sure the TV is set to the correct input source that the DVD player is connected to. For example, if the DVD player is connected to HDMI 1, then the TV should be set to HDMI 1 as well.
  3. Check the TV's settings. Some TVs have a "picture in picture" or "picture by picture" feature that may be turned on, preventing the main picture from showing.
  4. Check the DVD player's settings. Some DVD players have a setting that controls the aspect ratio of the picture. Make sure this is set correctly for your TV.
  5. Check the TV and DVD player compatibility. Some TV's are not compatible with older DVD players and this could be the reason for the lack of picture.
Cannot access TV. Screen shows HDMI 1. Invalid format.
Is it possible that whatever you have plugged into HDMI 1 requires a firmware update ? for example a dvd player etc
Or perhaps the tv cannot handle the resolution if this is the case you will want to set it at what the computer manual states what it can handle with HDMI
If not perhaps Unplug the tv for a few minutes, and then let it boot back up and trying your hdmi inputs again. This should reset the microprocessor.
Best of luck :)
No signal on tv screen
Is it registering the correct input? HDMI/ AV1/ AV2/ SCART!
I have no picture on DVD with scart lead on AV1 and no picture or sound on separate player on HDMI connections. both players work fine on other televisions.
Is the same HDMI cable you use in other TV.Will you properly check the plug of HDMI cable at the HDMI input of your TV and check the setting.
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
1helpful
No picture, can't set inputs on TV
try tighting the screws on the inverter. they sometimes get loose and then you lose the grounding.
HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
2answers
RCA DRC8052N DVD recorder
Try the input button on the DVD remote. You may have to move it to AV1 to get a picture??? Just a suggestion.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
