Remove the 3 screws holding the foot on and remove it.
Slide the insulator and blade clamp lever off exposing the gearcase.
At this point you can remove the gearcase from the handle and can access the entire tool.
Removing the gear assembly will require removing the nut (#18) at the front of the gearcase (under a plastic cover) (best done with a 13mm socket on an impact driver) then removing the blade clamp assembly allowing the mechanism to slide out.
The piece that holds the blade in is held in place by a spring that sometimes breaks. eReplacementparts.com has a diagram and sells the springs for 78 cents.
Remove the foot, remove the boot (and yellow lever), pull shaft out all the way (so you have more room to work with), remove the spring clip from the clamp block, remove the lever and ball, the clamp block will then slide off once the wire clip that wraps around it is removed.
could be quite a few things but it is obviously a loose connection in the electrical system, I would suggest going to dewaltservicenet.com and downloading a parts schematic before removing anything. I am thinking the battery or switch but try another battery first and look at the contacts for dirt or arcing. Let me know if you need more assistnace.
If you look at the end where the blade goes in, on the right hand side (as holding it for use in your hands) you should see a yellow lever.
First take out the battery, each and every time you change the blade.
Lift up the lever, wear some gloves to protect your hand and pull the plade straight out.
Push in the new blade with the teeth pointing down, and push the yellow lever down.
You can replace the battery once you have completed the above.
Hope that was of help to you.
Assuming you are cutting through material that your saw and blade are capable of cutting through - you either have a low or dying battery (if you have a bcakup battery - try that) - or you are using the wrong blade for the job - or it is dull. You can find battery replacements on Ebay. Blades are usually pretty cheap at the hardward store. Bring yours in and as someone in the hardware dept what they think about your blade. Good luck!
