SO- DIMM 512 MB 333 Mhz / 200 PIN PC2700 64Mx8
DDR SDRAM memory has 184 pins, where as SDRAM has 168 pins. DDR SDRAM Memory is a new type of SDRAM that is able to double the read / write speed of the previous generation of SDRAM memory. There are currently, PC2100 (DDR266), PC2700 (DDR333), PC3200 (DDR400), PC4200 (DDR533) These DIMMs are 184 Pin in size and are not interchangeable with older SDRAM modules.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Toshiba Satellite A15-S127: Memory does not show up
Is the BIOS up to date? if not you can download latest BIOS update from support.toshiba.com
SOURCE: RAM upgrade is not working
A 200-pin PC-3200 SODIMM should work in your machine but it will clock down to 333MHz. Your computer has 2 slots with a max of 512MB per slot (1GB total system memory). For maximum compatibility you should stick with a low density (16-chip - double-sided) PC2700 DDR-333 SODIMM with a CL of 2.5. Link below to see an example:
http://crucial.com/store/listparts.aspx?model=Pavilion%20ze4300%20Series
-E
