Use alcohol to clean the sticky grape juice residue form the lens barel. If that doesn't work, check this out:
Find Nikon Authorized Repair Station
SOURCE: lens error/system error
I have successfully fixed the same error on a Nikon 2100 by dissasembling the camera and removing grit from the gears that drive the lens. However, if the camera has been dropped, I suspect that something has got dented or bent. It may be worth taking the camera apart to see if a gear has got dislodged.
I would warn you to be very careful not to get a shock off the flash capacitor inside the camera though. Also, it took me quite a while to put it all back together. It's not the easiest device to work on, a result of the very compact body (for its time!)
SOURCE: lens error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: Lens Error - Cool Pix L6 - Camera unuseable
posted by DSabs on Sep 11, 2007
The lens is stuck open, and reads 'lens error' yet nothing seems to help it. It had been working fine, I went to take a photo and it stuck and came up wit the 'lens error' message. It seems to be permanently broken and it's only 4 months old. Help?!
I have this exact same issue!
SOURCE: stuck camera lens
i dont think you can do anything you just have to reffer to a proffessional because there are some gears that maybe damaged
SOURCE: I was using a Coolpix L20 when the lens stuck open
I have a coolpix l20 the lens is stuck Iam looking for a repair manual? Would like to fix it my-self
