Compaq Keyboard Logo
Posted on Dec 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My new packard Bell Onetwo M D6321 64 bit system will not function with Adobe Flash Player 10 Active X. Im using internet explorer (64 bit) as my browser. Adobe website keeps leading round and round saying that flash player 10.2 beta can be downloaded but all it downloads is Adobe Flash Active X again. Its all quite confusing. Any solutions
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Dec 31, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557110
Points
31058
The component is named 'ActiveX'.
The version of the Adobe Flash Player was 9-point-something, but now
the current version of the Adobe Flash Player is 10-point-something.
So, use Add/Remove Programs to _remove_ Adobe Flash Player.
Restart your computer.
Access: http://www.adobe.com/software/flash/about/
and allow the ActiveX control downloaded from Adobe to be installed.
2answers
Packard Bell OneTwo M3700 PC boots up but no display
most of the time on older monitors you can set the refresh rate in safe mode and that will, most of the time, resolve the problem otherwise time to purchase a newer monitor.
2helpful
I download adobe flash player and it says download is successful but when i check it in my programs list the name is there but the size shows nothing. when i try to use it, my computer tells me that i need...
Hi tanis59
You are probably using Windows 7 64 bit . IE 64 bit is not yet ready to integrate Flash Player 10.1 and you need to use IE 32 bit . You will find it here : Start / All Prgrams / Internet Explorer . Select IE and not IE 64 bit . It will download and install Flash Player on your machine .
Best regards ,
fanaudi .
I have problem with my youtube, videos are not playing.. pls help!
Make sure that your flash player is installed. You can go to http://www.adobe.com/ and click on adobe flash player.
If you're using a 64 bit browser, make sure that you use the 32 bit internet explorer instead of the 64 bit internet explorer (If you click on start > all programs, you will see 2 internet explorers, a 32 bit and a 64 bit).
Let me know if this helps :)
I play a game on facebook, and every time I go into the game, a screen says my plugin has crashed. What do I do to fix it?
Depend on your OS. If is Windows IE, some issues has found on this.
Try this :
our version of Windows is either a 32-bit operating system or a 64-bit operating system. A 64-bit operating system can run both 32-bit applications and 64-bit applications.Your browser, such as Internet Explorer, is either a 32-bit application or a 64-bit application. Flash Player works only with a browser that is a 32-bit application. On a 32-bit operating system, your browser is always a 32-bit application. However, on a 64-bit operating system, your browser is either a 32-bit application or a 64-bit application. Make sure you are using a 32-bit browser by following these instructions:
Windows with Internet Explorer
To make sure you are using a 32-bit version of Internet Explorer, follow these steps:
  1. In Internet Explorer's Help menu, select Help > About Internet Explorer. (In some versions of Internet Explorer, select the question mark in the upper right corner to select About Internet Explorer).
  2. If you do not see the words "64-bit Edition" next to the version number, you are running a 32-bit version of Internet Explorer. Continue to Determine the Flash Player version you installed, if any.
  3. If you do see the words "64-bit Edition", go to Flash Player on 64-bit operating systems (TechNote 6b3af6c9) to continue troubleshooting your Flash Player installation.
Windows with other browsers, such as Firefox, Google Chrome, or Opera
No official 64-bit version of these browsers is currently available on 64-bit Windows operating systems. Therefore, unless you are using a test version of a browser (not typical), your browser is a 32-bit application, and therefore, works with Flash Player. Continue to Determine the Flash Player version you installed, if any.
2. Determine the Flash Player version you installed, if any
Before you troubleshoot Flash Player installation, determine the version of Flash Player you have installed, if any. You can see if it is working and whether it is the latest version available for your operating system. Follow these steps:
  1. Go to http://www.adobe.com/software/flash/about. If you have already successfully installed Flash Player, the page displays the Adobe Flash Player version as shown in the following image:
    Note: The version number in this example might be different than the version you have installed.
    If you have not successfully installed Flash Player, you will not see the image.
  1. The same page http://www.adobe.com/software/flash/about has a table that shows the latest Flash Player version available for your operating system (for example, Windows or Macintosh) and your browser (for example, Internet Explorer or Firefox). If the version information shown in step 1 does not match the latest version shown in the table, upgrade to the latest version. To upgrade, continue to Uninstall previous versions of Flash Player.
Note:Internet Explorer uses a different Flash Player than other browsers such as Firefox or Google Chrome. Therefore, if you sometimes use Internet Explorer and sometimes use another browser, you might have installed a different version of Flash Player for Internet Explorer than for other browsers.
3. Uninstall previous versions of Flash Player
Before you install Flash Player for any Windows browser, uninstall all previous Flash Player versions and restart your computer. Follow these steps:
  1. Uninstall all previous Flash Player versions and restart your computer. For Flash Player uninstall instructions, see Uninstall Flash Player (TechNote tn_14157).
  2. Restart your computer after uninstalling.
  3. If you are using Internet Explorer, continue to Verify Internet Explorer security and ActiveX settings. Otherwise, continue to Download and install Adobe Flash Player.
4. Verify Internet Explorer security and ActiveX settings (skip for other browsers)
Make sure that Internet Explorer security default level is set to Medium. This level allows viewing ActiveX controls, such as Flash Player. To set browser security to Medium, perform the following steps:
  1. Open Internet Explorer.
  2. Choose Tools > Internet Options.
  3. Select the Security tab.
  4. Select Trusted Sites zone.
  5. Select the Default Level button. (If the Default Level button is dimmed, continue to the next step).
  6. Move the slider until the security level is Medium.
  7. Select Apply.
  8. Select the Internet zone.
  9. Repeat steps 5 - 7. When done, select OK.
12helpful
3answers
Adobe Flash Player
If you want to download flash player you can use the links below to download flash player:
Flash Player 10,0,12,36 Active X (for Internet explorer)
http://tinyurl.com/67twte
Flash Player 10,0,12,36 Plug-In (for Firefox,Netscape,Safari,Chrome,etc)
http://tinyurl.com/8nz9s
1helpful
Can't get Adobe Flash Player 9 ActiveX.exe to download.
Flash player 9 is actually not the latest version. If you want to install the latest version which is version 10, follow the steps below:
a. Download the most recent Flash Player uninstaller to your desktop from the TechNote below. Please read the instructions in the TechNote before running the uninstaller.
How to uninstall the Adobe Flash Player plug-in and ActiveX control
http://www.adobe.com/go/tn_14157
b. Quit ALL running applications, including all Internet Explorer windows, other browser windows, AOL Instant Messenger, Yahoo Messenger, MSN Messenger or other messengers. Check the Windows system tray carefully to make certain no applications which might possibly use Flash Player is still in memory.
c. Open the following folder: C:\WINDOWS\system32\Macromed\Flash
d. Run Flash Player uninstaller.
e. Check if there are files left in the folder: C:\WINDOWS\system32\Macromed\Flash. If there are any files left inside the folder, delete the files.
f. Download and install the latest Flash player at:
2answers
Adobe flash player
you can use the links below to get a downloadable installer for Flash player:
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
