Hi this sounds like the pocket wifi firewall or push is stopping you from connecting, it will show connection when the password is put in correctly, but unless your either ip, or mac address is registered with the unit it will not let you connect to the net, you will have to see if there is a start ip and an end ip address in the wifi unit, as this might have restrictions to ip address numbers..for example..wifi ip start address might be 192.168.0.1 and wifi end address might be 192.168.0.4 where as your ipod might have an ip address of 192.168.0.7 ( just an example ) so even though the password is ok, it will let you connect for that few seconds, as it has verified the password and is correct, but the ip handling has not allowed you access and the firewall then steps in and blocks you.... hope this helps
