This issue can occur in the following circumstances:
The subject is too close to the camera lens
Insufficient lighting
Subject movement
Camera movement
Incorrect camera settings
Incorrect camera operation
Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus.
Make sure there is enough lighting to allow the camera to focus on the subject.
Make sure the camera settings are set appropriately.
When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position.
If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting.
If your camera has a SteadyShot/anti-blur function, ensure it is enabled.
Aim the camera at the subject.
Press the shutter button halfway down.
NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture.
Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Lens is dirty
