There is a chance the water is coming from the drip tray and or the drain hose to the tray.
when the unit goes into a defrost cycle it is leaking from one of those places check and make sure the hose is in the drip pan correctly and that the pan is also mounted properly and level.
If there is is a lot of water in the pan you may need to check the door seals on you unit and make sure they are sealing properly.
If there is an air leak then the unit could have excessive ice build up and also be defrosting more than usual amounts of water.
