PASSIVE ANTI-THEFT
YES
TRANSPONDER
SEE NOTES
12 VOLTS
Yellow
Ignition harness
IGNITION
RED / green
Ignition harness
IGNITION 2
Blue/green
This wire is only required on the V-10 Gas engine.
ACCESSORY
RED / black
Ignition harness
ACCESSORY 2
Gray / YELLOW
Ignition harness
STARTER
Dk.green
Ignition harness
KEY SENSE
BLACK/ pink
In airbag plug on right side of st. column
TACH SIGNAL
Use an injector
DIESEL TACH SIGNAL
GREEN / WHITE
SEE NOTES
Look below the relay box under the dash for a large loomed harness. There are some wires taped to the harness terminated with heat shrink tubing. You will find the GREEN / WHITE among these wires.
LOCK
WHITE/ red
In harness above gas pedal
On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel.
UNLOCK
BLACK/ white
DRIVER LOCK MOTOR
Pink/black
DRIVER UNLOCK MOTOR
RED / orange
PASSENGER UNLOCK MOTOR
Pink/orange
GLO-PLUG SIGNAL
DATA ONLY
USE DELAY TIMER
DOORPIN
BLACK/ blue
Above parking brake in DKP
The vehicle's computer sends out diagnostic pulses on this wire every 15-20 minutes. This may cause an after-market alarm to false. It is suggested that you add a relay to this wire when connecting to an alarm system. See the appropriate diagram for exact wiring instructions.
FACTORY ARM
Yellow/black
This is the driver's doorpin wire. Pulse this wire at the same time as lock to arm the factory alarm.
FACTORY DISARM
Dk.GREEN/ purple
BRAKESWITCH
Green
At switch above brake pedal
PARKLIGHTS
Brown
At light switch harness
HAND BRAKE
Lt.GREEN/ red
At plug above handbrake lever
HORN
Dk.blue
