Maytag EPIC MFW9700S Front Load Washer Logo
Posted on Jan 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F71 - Maytag EPIC MFW9700S Front Load Washer
sonic boom electronics
Level 3:
  • Master 1,557 Answers
  • Posted on Jan 02, 2011
Master
Level 3:
Answers
1557
Questions
Helped
386527
Points
5474
Select POWER/CANCEL twice to cancel the cycle.
Select DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START/PAUSE.
If the problem remains, schedule service.*
Troubleshoot washer code reads F71 no displays
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
My washer is not operating properly. please tell me what code F71 means and how to fix the problem. Thank you.
Regards.
1helpful
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
Regards.
Getting code F70 and F71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool Duet washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
What does F71 mean ? This comes up half way through the cycle
Regards.
Error code shows F71. door is locked and there are clothes in there soaking in water that I need to get out!! what does F71 mean and how do if solve the problem
Hi.
Sorry for the late reply.
If you get similar problems in the future, and machine gets stuck in error mode with clothes inside, empty water from tub disconnecting the drain filter, located behind a panel in front lower side of appliance. After emptying water the door will normally get opened.
Regards.
Getting code f70 & f71 washer will not run water does not fill or spin
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
Regards.
Ginko.
There is an error code f70 and there was an error code f71.
Hi.
Regards.
Ginko.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
