hi,
Dictionary installation on Samsung SGH-L700
Maximum dictionary size recommended by producer: 60KB
Maximum dictionary size tested: not tested yet
You can often overstep the maximum size limits, so try to install the dictionary proto on your mobile even if it is larger than recommended, or it has not been tested yet.
Installation procedure
First of all you need to have Samsung PC Studio installed on your computer. To download it, go to
Samsung Download Center and choose the model name of your mobile.
Installation using Samsung PC Studio:
- Connect phone to PC
- Run Samsung PC Studio if not running
- Open file manager (Click "Manage Files")
- Copy .jad and .jar to "Other Files" folder on phone. (You can download these files from our website)
- Disconnect phone and go to "Other Files", run .jad file to install and run the application.
If a message "
Unsupported file format" appears, then it means that installing applications from PC is blocked in your mobile. In that case the simplest solution is to
install per WAP. There are also ways to bypass this limitation and unblock the mobile. Try to search Google for eg. "
L700 install jar" (witnout quotation marks) or "
Samsung SGH-L700 Unsupported file format"
