You can purchase Quinny Buzz adaptors via your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) RRP is 10GBP a pair plus 3.99GBP p+p if ordered direct. These adaptors will fit a Maxi Cosi CabrioFix, a Maxi Cosi Pebble, or a Quinny Folding Carrycot to the Quinny Buzz chassis.
hi you can get a new wheel unit from quinny direct or eBay the folding is something else turn the buzz over and check the groove on the middle tube to see if it is clean try an oil like wd40 if that doesn't work it may need a re gas which can done by quinny
hi i'm not sure you can fold the buzz with dreami still attached here are upto date instructions for the dreami http://www.quinny.com/media/producthandleidingen/Quinny/2009%20Manual%20Buzz%20Dreami%20UK.pdf
for the buzz http://www.quinny.com/media/producthandleidingen/Quinny/2009%20Manual%20Buzz%203%20UK.pdf
after reading them i would say it has to be removed(I only had the pushchair)
Hi, apply the brake.
Go round to front of buggy.
Hold the 2 large grey buttons on side of frame.
1 pushes down 1 pushes forwards do this & pull buggy down towards you, this will fold it as long as the brake is on.
Hi you need to apply the brake 1st. then stand at the front, there is 2 grey buttons either side of the seat on the 2 round bits. 1 you push down the other you slide forwards, keep hold of them & pull it downwards towards your feet. This will then fold down.
