Toshiba 32AV502R LCD TV Logo
Posted on Jan 03, 2011
I have the Toshiba TV Model # 32AV502R. I lost my user gaide, I input my DVD player in the TV but I forgot how to get to the channel that I can watch DVD. Can anyone help?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
156
Points
I cant get anolog and digital channels on my tv i dont have a manual
How do i set my Toshiba ct-90157 remote to watch dvd's
Most DVD players are connected to one of the rear audio/video inputs--hook to that input and select it on the TV--then hit play and if connected correctly you will see the movie.
1helpful
I have a D-VR7KC2 DVD VIDEO RECORDER. Is there any way to hook it up, so that I can record a channel, while watching another channel? I have a digital cable box. I don't mind only being able to record non...
The short answer is "yes", but it really depends on your TV having more than one input.
You would put a cable splitter (see Google images) on the wire that comes out of the wall. One of the OUT connections would be to the cable box, and the other would go directly to your Toshiba unit.
Depending on the outputs of your cable box, and the inputs of your TV, each unit would be connected to a TV input either by cable or video connections. You would then switch back and forth between the input from the cable box - when you wanted to watch live, digital TV - or the Toshiba when you wanted to set up/watch recordings.
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Hooking up DVD player
does it have an AV or INPUT button on the remote
if so connect your dvd and scroll through these inputs
hope this helps if not email
[email protected] and i will help
2answers
I just got a toshiba theaterview sd dolby digital
That particular TV has both "component video" and standard video inputs. The DVD player might have a component video output (it will be three separate connectors of three different colors.) You will need a component video patch cable available at most electronics stores. If your DVD player doesn't have that input then use the standard video connector, yellow wire connects the video out on the DVD player to the Video input on the TV. The red and white wires are the left and right stereo audio connections they also make a cable for that. It will be color coded so make sure you match the codes from the output to the input on the TV. This set has two video inputs, you will get your best resolution if you use them instead of a "channel" input.
You will need the remote to select the video 1 or video 2 inputs. You can connect your DVD player and your game at the same time. Just use video 1 for the DVD and video 2 for the game. They require the yellow, red and white connector cables. Just follow the color code and match the colors with the jacks on the TV and other units. There is actually a third video input Video 3 behind the little door on the front panel. That would be convenient for the game if you want to remove it easily when not in use.
Push the menu button on the remote (big button in the middle) go to the video function and select either Video 1 for your DVD, Video 2 or 3 for your game.
The correct video input for what you want to view is important. Also if you don't have the user's manual it's available for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2003/32A33_32_36A43%28E%29_A.pdf
You might also need to download an Adobe Viewer which allows you to read .pdf files.
That is also available for free at:
http://get.adobe.com/reader/
If you already have malware protection (viruses and the like) un-check the MacAfee box so you don't download that too.
Zashiban
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
I have a 19 sylvania tv that I want to connet toToshiba DVD playe
If the TV doesn't have AV input jacks, you'll need an RF converter so you can watch the DVD player on channel 3 or 4. You can find them at Radio Shack, Wal-Mart, Home Depot and most places that sell TVs for around $15. Connect the audio and video from the DVD player to the inputs on the converter, and the converter's output to the TV antenna jack. Set the TV to whichever channel the converter is set for (3 or 4, with a switch on the converter so you can choose) and you'll be in business.
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
