Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Posted on Jan 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LIGHTS DON'T WORK PROPERLY.. THEY WILL SEEM TO BE BURNT OUT AND THEN I GO IN AND TIGHTEN THE BULB AND THEN THEY WORK FOR A FEW DAYS AND THEN THEY STOP WORKING AGAIN. IT SEEMS LIKE THE BULB IS NOT MAKING CONTINUAL CONTACT. WHAT SHOULD I DO?
Anonymous
Level 3:
President:
  • Master 3,197 Answers
  • Posted on Jan 03, 2011
Anonymous
Master
Level 3:
President:
Answers
3197
Questions
Helped
1457997
Points
8183
Unplug the opener and remove the bulb. Use a small screwdriver and pull out on the center contact of the light socket. Replace the bulb and plug the opener in.
hsapiens
Level 1:
  • Contributor 6 Answers
  • Posted on Dec 09, 2018
hsapiens
Contributor
Level 1:
Answers
6
Questions
Helped
2085
Points
23
I wrapped a bit of teflon plumbing tape on the threads of my garage door opener light bulbs. This prevented them from vibrating loose. If you do this, make sure not to cover the threads completely, as this will prevent power from flowing. Just wrap the portion closest to the "head" of the bulb.
My opener is a few years old, and not the latest model. After a power outage the lights no longer came on every time we walked in or out (while carrying a load groceries that required multiple trips, for instance). Most of the online advice I found said the circuit board in my opener must be replaced to correct this, but I had a vague recollection that this feature can be turned on & off on my opener (apparently not the case with newer models). After digging awhile, I found LiftMaster's instructions online (https://support.chamberlaingroup.com/s/article/How-to-activate-or-deactivate-the-light-feature-or-adjust-the-light-timer-on-the-Multi-function-door-control-1484145515542). They say to close the door and while the lights are still on, hold down the Light button on the door control. The lights will go off; continue to hold the Light button down and they will come back on. The opener is now programmed to turn the lights on upon entry/exit. It worked for me.
I've shorted out my oven after attemtping to change the light bulb.
most ovens will not operate until you set the clock - doesnt matter what you set it to as long as it isnt 00:00
1helpful
WHY DON'T MY FRONT MAKER AND RUNNING LIGHT WORK
front side marker lights are separate from the day time running lights which are run thru the front turn signal lamps.
it is possible both bulbs have burnt out.
I need to find the flasher relay for a grand marquis 2001 .does it has one? My turn signals wont work I can hear the sound but don't even flash
Yes, it does have a flasher, although it may be a combined unit with the hazard flashers relay. So you hear the clicking of the flasher relay? That seems to indicate the relay is working properly. Have you checked the bulbs and the turn signal fuse? Any turn signal bulbs light up anywhere, front or back?
How about your brake lights, do they work? Your car may have separate, stand alone turn signals in the rear, but many American cars use the same bulb and same filament on the bulb for the brake lights and turn signals. If your merc is like this and the brake lights work, then the bulb must be good.
Turn on the hazard flashers and see if all bulbs work and flash at each corner of the car. This would be the same bulb as for the turn signals. If they work, it could be a bad turn signal switch, may even be the flasher relay somehow malfunctioning, and in a few cases, a bad hazard switch can affect the turn signal switch. Check fuses and bulbs first. If you have any type of body control module that controls lights and other accessories, you may have to investigate that. I know I'm not being very helpful, just throwing out a few suggestions. Good luck.
Only one of the window brake lights work and the rest don't, i checked the bulbs and they seem to be ok.
If the light sockets are not burnt try new bulbs,even if the old ones appear fine.
John
2answers
Rear tail and brake lights out 97 Jetta
I believe this car has a bulb with two fillaments for side and brake lights, it is unlikely that they are both burnt out at the same time but possible. It is more likely that the bulb holder or a ground connection is rusted or loose. The fuse generally covers all rear lights.
1helpful
Light bulb went out in model # ED20TKXDN01. I replaced bulb and it still does not work.
Good day,
I have run more than one call for this complaint only to find the bulb was not tightened enough. But ......
Other options are, the light switch failed, and needs to be replaced. The old one needs to be pried out and unfortunately it can be ruined in the process. But that's the process.
The last common problem, is the socket itself has failed, and the assembly must be replaced.
I know, irritating sometimes.
A while back, I ran into a batch of GE bulbs that for some reason would not seat properly. Seemed O.K. but would not work. Changed brands and everything was fine.
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
